https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> ranking distortion components https://designers-guide.org/forum/YaBB.pl?num=1196709118 Message started by orion on Dec 3rd, 2007, 11:11am |
Title: ranking distortion components Post by orion on Dec 3rd, 2007, 11:11am :(I wanted to rank distortion contributors from different devices in my circuit but could not get it to work. Attached is a slide from a Cadence seminar. For myself, I only got it unranked and in complex numerical form that makes it difficult to be of much use. To set up, on my ckt source, I place a value for the power in the AC magnitude or PAC magnitude then in the analysis line of the ADE, under Specialized Analysis, I pick Compression Distortion Summary. Then after simulation is completed, I plot it out using Results->Print-> either AC Distortion Summary or PAC Distortion Summary. But the results does not look like the enclosed JPEG file(distortion contributers are ranked and distortion is printed in terms of magnitude) from a Cadence seminar that I went to. I am using MMSIM6.2 under ADE5.10.41.500.4.73. I am wondering if I need to go to ADE 6.1.1 to get this. |
