https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> bandgap articles https://designers-guide.org/forum/YaBB.pl?num=1197146382 Message started by grosser on Dec 8th, 2007, 12:39pm |
Title: bandgap articles Post by grosser on Dec 8th, 2007, 12:39pm hello can you recommend any schematic of the bandgap which will consume low current <5uA and will ensure quite good accuracy ? the technology is CMOS 0.35um regards |
Title: Re: bandgap articles Post by Berti on Dec 9th, 2007, 10:15pm Hi, Since most bandgap circuits follow the same principle, whether your circuit will only consume only 5μA or not will be determined by your noise requirements. Regards |
Title: Re: bandgap articles Post by SATurn on Dec 30th, 2007, 2:21pm Hi, You may minimze the power consumption of your BGR circuit using the technique introduced in: Tajalli, et al., ISCAS 2004. The power consumption depends on the resistors exist in your technology: high sheet resistance better chance for reducing the power consumption. SATurn |
