https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> parameterized Simulation with CADENCE ADE https://designers-guide.org/forum/YaBB.pl?num=1197622819 Message started by RadioFreeq on Dec 14th, 2007, 1:00am |
Title: parameterized Simulation with CADENCE ADE Post by RadioFreeq on Dec 14th, 2007, 1:00am Hi there, Iīm simulating 1 BAW-Filter composed of many BAW-Resonators in a Ladder structure. I have an accurate Model for the BAW-Resonator for Which you have 4 Parameter to change, lets say P1,P2,P3 and P4. depending on these Parameters the values for the components of the model can be calculated. so there must be internal functions in the Model-schematic that calculate the values for each component of this Model when the 4 Parameter are Input. The Filter is Composed of 3 Stages of series-parallel Resonators with different Parameter value for each stage. I donīt know how to implement this in CADENCE. I need something like: I input the 4 Parameter for each Resonator in the Filter Structure and internally the values for each model are calculated and then I simulate and optimize. there is only 1 Model for Resonator. So itīs like having a Resistor (example) and you change its value each time you use an instance of it, but in my Problem you give 4 values and internal values will be computed. S.O.S |
Title: Re: parameterized Simulation with CADENCE ADE Post by RadioFreeq on Dec 14th, 2007, 1:30am I found something with pPar, but I need to implement a function in the schematic which calculates some intermediate valus that serves calculating the values for the model components.. |
Title: Re: parameterized Simulation with CADENCE ADE Post by sheldon on Dec 15th, 2007, 6:52am Radio, Here are a some things that I have used to parameterize a design, 1) You can create parameterized schematics for blocks using pPar, for example, create a biquad section and parameterize the R and C in terms the natural frequency and Q. When the multiple biquads are cascaded, the frequency and the Q of each section can be optimized to give the best overall transfer function. 2) Instead of using fixed values for instance parameters, you can use equations, for example, define the frequency of a source as (tone/numPoints)*fsample. In this case the source is used as the input signal for an ADC, the frequency is automatically calculated based on the design variables set by the designer. 3) As an alternate to #2, you could create dummy design variables and do the calculation using dummy variables. So I would create a parameterized schematic using pPar for the BAW element using the parameters P1, P2, P3, and P4. Then I would create the overall schematic, 3 stages of series-parallel resonators and use design variables for the instance values. Then you can do parametric sweeps or any other analysis you would like. Best Regards, Sheldon |
