https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> A question about delta sigma modulators stability https://designers-guide.org/forum/YaBB.pl?num=1199359045 Message started by aidnaal on Jan 3rd, 2008, 3:17am |
Title: A question about delta sigma modulators stability Post by aidnaal on Jan 3rd, 2008, 3:17am Hi, In delta sigma modulators the maximum SNDR is given by the famous equation of Shreier book; But in most cases this is not valid and the measured or simulated SNDR is below this value. In Shreier book it's said that in an unstable DS modulator the SNDR is below this value, and the unstability causes the degradation in SNDR. Could you please explain that what is the criteria for stability and how we can recognize if a modulator is stable or unstable? Thanks a lot. |
Title: Re: A question about delta sigma modulators stabil Post by Berti on Jan 6th, 2008, 10:16pm It is not possible to give an accurate analytical expression for the overload level (stability) of a DS modulator. However, check CLANS (NTF optimization tool), which is part of R. Schreiers DS-toolbox for matlab. There it is described how stability is determined without simulation. Regards |
Title: Re: A question about delta sigma modulators stabil Post by thechopper on Jan 20th, 2008, 5:05pm Another extra piece of info. In that book youŽll find that stability can be predicted based on the value of the NTF as frequency approaches infinite. The criteria change depending on the modulator being single or multi bit. Regards Tosei |
