https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> question about switches https://designers-guide.org/forum/YaBB.pl?num=1199615213 Message started by James Bond on Jan 6th, 2008, 2:26am |
Title: question about switches Post by James Bond on Jan 6th, 2008, 2:26am Hi, all, I designed a switch to switch off the capacitor, during the simulation when switch is off, I found that the AC signal is almost blocked, with 0.9Vpp input to the switch, only 0.5mVpp passed, but the input signal has a dc level about 0.9V, and after the switch, it has a dc level about 0.4V, Can I consider the switch is off ? Since after swith is the capacitor, so I think the dc will not affect my ac operation , right ? Please give me some suggestions.Thank you very much. james |
Title: Re: question about switches Post by ywguo on Jan 6th, 2008, 9:57pm Hi James, Would you please post the schematic and the waveform? I think that the switch is switched off. Yawei |
Title: Re: question about switches Post by Berti on Jan 6th, 2008, 10:13pm Hi, Since the switch is off, you basically have a capacitive voltage divider. Therefore you can easily calculate whether the 0.4V is reasonable or not. Regards |
