https://designers-guide.org/forum/YaBB.pl Design Languages >> VHDL-AMS >> sample and hold https://designers-guide.org/forum/YaBB.pl?num=1199630127 Message started by safwatonline on Jan 6th, 2008, 6:35am |
Title: sample and hold Post by safwatonline on Jan 6th, 2008, 6:35am i am new to VHDL-AMS and i am trying to model a sample and hold block in time domain. i made this code but it aint working any hints please ! Quote:
Title: Re: sample and hold Post by mikej on Jan 8th, 2008, 11:38am Try using the zero-order hold ('zoh) attribute, which is essentially a sample-hold function. The attribute can be used with any quantity and has the following syntax: Q'zoh(T,initial_delay) where "Q" is the quantity to be sampled, "T" is the sampling interval, and "initial_delay" is the delay before the first sample is taken. The result of the command is a quantity of the same type as Q. Time T must be a static expression of type real and greater than 0.0. Initial_delay must be a static expression of type real and non-negative. If you don't need a delay before the first sample is taken, you can use the following syntax: Q'zoh(T) |
Title: Re: sample and hold Post by safwatonline on Jan 9th, 2008, 12:18pm Thanks for ur answer, but i want the model to sample the analog input quantity when a clock signal coming from another terminal arrives i.e. i want to sample on the edge of a signal coming from a terminal and not at fixed period. |
Title: Re: sample and hold Post by Sameer Kher on Jan 10th, 2008, 1:48pm The code looks ok for what you are trying to do. Perhaps the problem is elsewhere? What results do you get? BTW, the electrical systems package has been standardized for a while now (no longer proposed). You should use LIBRARY IEEE; USE IEEE.ELECTRICAL_SYSTEMS.ALL; ... Hope this helps. Thanks, Sameer |
Title: Re: sample and hold Post by safwatonline on Jan 11th, 2008, 6:19am Sameer Kher wrote on Jan 10th, 2008, 1:48pm:
the output is not following the input , it is zero and doesnt change either with the clock or input |
Title: Re: sample and hold Post by didac on Jan 11th, 2008, 6:59am Hi, Haven't work with behavioral description for a while but I think that you should include the clk signal inside the sensible list of process(if not included I think that it will never activate): process(clk) begin end process; Hope it helps, |
Title: Re: sample and hold Post by Sameer Kher on Jan 11th, 2008, 1:28pm didac, all, With VHDL-AMS, you either specify the process sensitivity list or have appropriate wait statements to ensure that your process is correctly triggered. So the code should work. Perhaps you can verify that the problem is indeed only in the S&H model by using it by itself (assuming you are using it in a system). It may be an implementation bug in the software. Good luck, Sameer |
Title: Re: sample and hold Post by safwatonline on Jan 12th, 2008, 9:11am Sameer Kher wrote on Jan 11th, 2008, 1:28pm:
yep, it is not working by itself, maybe someone can share a working sample and hold code thanks |
