https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> ocean script for montecarlo analysis https://designers-guide.org/forum/YaBB.pl?num=1200505776 Message started by ENNIOJ82 on Jan 16th, 2008, 9:49am |
Title: ocean script for montecarlo analysis Post by ENNIOJ82 on Jan 16th, 2008, 9:49am Hi , I had to do a script ocean that take the result from a montecarlo analysis Resul directory ./Sim....../psf and put them into a array o a list..... The result must be in like Num iter;OUT_27 ( a result for every Run ) OUT_27 is a parameter of the analysis It should be a result like IterVsValue("OUT_27") but this return the result on screen ,instead i had to print this in a list..... Can someone help me? Thanks |
