https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> SpectreRF simulate VCO phase noise with divider https://designers-guide.org/forum/YaBB.pl?num=1200581479 Message started by neoflash on Jan 17th, 2008, 6:51am |
Title: SpectreRF simulate VCO phase noise with divider Post by neoflash on Jan 17th, 2008, 6:51am Since I failed to get reasonable result, from EldoRF, for a cascaded VCO and divider, I turned to spectreRF. I'm simulating a 5G VCO with a cascaded divider-by-4. I'm probing phase noise at the output of divider. When I setup the beat frequency as 5G and put probe at VCO output, the pss analysis can not converge. However, when I put the probe at divider output and set beat frequency as 1.25G, the simulation converged with some warning. I'm not sure whether it is the correct setup. Since spectreRF is more used among people, hope i can get some help. Thanks. |
Title: Re: SpectreRF simulate VCO phase noise with divide Post by Stefan on Jan 17th, 2008, 6:53am Put probe output on vco but set beat frequency to 5G / 4 = 1.25G Slowest frequency in circuit should determine you period for the PSS. |
Title: Re: SpectreRF simulate VCO phase noise with divide Post by neoflash on Jan 18th, 2008, 1:52am Yes, thanks. I found the results are different if I put probe at divider output. |
