https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> Noise https://designers-guide.org/forum/YaBB.pl?num=1203017629 Message started by safwatonline on Feb 14th, 2008, 11:33am |
Title: Noise Post by safwatonline on Feb 14th, 2008, 11:33am Hello, i am doing a SC design with a tough spec on noise using eldo, so i am currently using the transient noise of mentor and i was wondering of how accurate is it. (sadly i don't have access to spectre RF) also i saw a thread here on the forum talking about using a "fracpole" to model the 1/f noise, Sorry but what is the fracpole!! regards, Safwat |
Title: Re: Noise Post by Ken Kundert on Feb 14th, 2008, 3:54pm I can safely say that the accuracy anywhere near as good as SpectreRF, but you should also be aware that there is a nasty tradeoff between speed and accuracy with transient noise. That is particularly true if you hope to include flicker noise. That is going to be one long simulation. FracPole is a component that implements a fractional pole (or zero). It is described in some detail in several papers in the Modeling section of this site. -Ken |
