https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Help: identify certain ELDO BSIM3 model paramters https://designers-guide.org/forum/YaBB.pl?num=1203612952 Message started by spitalny on Feb 21st, 2008, 8:55am |
Title: Help: identify certain ELDO BSIM3 model paramters Post by spitalny on Feb 21st, 2008, 8:55am I have some BSIM3 spice models intended for use with ELdo. There are some parameters in the models that my simulator does not recognize. So, I am trying to understand what the paramters are and see if my simulator just has a different name for the same parameter, or not! Here they are: 1) flkflag this appears i n the beginning of the mod model file 2) pg has something to do with source/drain diodes I think 3) dcaplev has something to do with source/drain diodes I think 4) alev also has something to do with source/drain diodes I think If yo uknow anything that could help it would be greatly appreciated! Also, if you know of any good online version s of the Eldo user mnaul/mode manual that would be tremendously helpful! Thanks! P. |
