https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> PDK install in IC610 https://designers-guide.org/forum/YaBB.pl?num=1203989634 Message started by jimwest on Feb 25th, 2008, 5:33pm |
Title: PDK install in IC610 Post by jimwest on Feb 25th, 2008, 5:33pm Hi folks, I am stucked while installing the pdk in IC610. Is IC610 compatible with the pdk which is not an open access one? I searched the menu in CIW and found out there is an OA translator. But I failed to open the library by applying the translator. Is there any solution? Kindest Regards, Jim |
Title: Re: PDK install in IC610 Post by Frank Wiedmann on Feb 26th, 2008, 12:01am As far as I know, IC610 only exists for OA. I see three possible solutions:
