https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Re-running particular monte-carlo run https://designers-guide.org/forum/YaBB.pl?num=1204290386 Message started by parth_sv on Feb 29th, 2008, 5:06am |
Title: Re-running particular monte-carlo run Post by parth_sv on Feb 29th, 2008, 5:06am Hi All, I am currently running a monte-carlo simulation for a sub-block. I need to take the worst case of the 'N' runs and use that particular monte-carlo run(Vt variation say) at higher-level(more blocks put together) to check the total effect. How can I save that particular run and use it in different spectre run? Thanks in Advance, Partha |
Title: Re: Re-running particular monte-carlo run Post by achim.graupner on Mar 3rd, 2008, 3:04am Hi Partha, once you have identified your worst case run, use this number in the field "First Run" and "number of Runs" 1, This repeats this single simulation and allows further analysis. Regards, Achim |
Title: Re: Re-running particular monte-carlo run Post by Frank Wiedmann on Mar 3rd, 2008, 3:34am I also like to use this method. However, I don't think it can be used in his case because it only works if the circuit is not changed and he wants to use the results in a larger circuit. |
