https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Frac-N PLL paper: error in paper by Mentor? https://designers-guide.org/forum/YaBB.pl?num=1204311472 Message started by Visjnoe on Feb 29th, 2008, 10:57am |
Title: Frac-N PLL paper: error in paper by Mentor? Post by Visjnoe on Feb 29th, 2008, 10:57am Dear all, I would like to have a second opinion on a Mentor Graphics paper on simulating fractional-N PLL synthesizers. In the paper "Efficient Simulation Techniques for Modulated Delta-Sigma Fractional-N Synthesizers" by Cyril Descleves (Mentor Graphics Corp), which can be download from their website, the simulation of a fractional-N PLL is discussed. In this paper, the FFT of the VCO tune voltage is shown, taken from a closed loop PLL simulation. Note that the FFT is plotted versus a linear frequency scale (Fs=Fref=26MHz). What can be seen nicely on this picture is the noise shaping from the delta sigma modulator. No problem so far. I have than tried to recreate this simulation output (same reference frequency, same loop filter components etc.), but I observe a different FFT output. Namely, beyond the loop filter bandwidth, the VCO tune voltage is decreasing with 20dB/decade. This could/would be the loop filter kicking in, filtering off the sigma delta quantization noise. So, basically, I do not obtain the large 'horizontal' part in the graph. Since I run these simulations using a FastSPICE simulator, I'm not 100% certain this is not a simulation accuracy issue. If it is not, it would mean that the graphs in the Mentor Graphics paper are incorrect. Any comments more than welcome. Kind Regards Peter ps: please note that I'm not using Mentor tools to recreate this graph |
Title: Re: Frac-N PLL paper: error in paper by Mentor? Post by Visjnoe on Mar 1st, 2008, 12:50am Dear all, I have found the answer to the puzzle. The delta-sigma in the Mentor paper is of 4th order, while the loop filter is of 3th order. Therefore, the quantization noise beyond the loop bandwidth is passed through with a constant gain of 0dB, resulting in the 'horizontal' spectrum. Kind Regards Peter |
