https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Automatically calculating AD, AS, PD, PS, etc https://designers-guide.org/forum/YaBB.pl?num=1205206548 Message started by RobG on Mar 10th, 2008, 8:35pm |
Title: Automatically calculating AD, AS, PD, PS, etc Post by RobG on Mar 10th, 2008, 8:35pm I know this can be done easily, but I can't seem to get to first base. When I place a mosfet using the cadence schematic capture tool, and give it a certain width, I would like the AD, AS, parameters automatically filled out (even if I have to use simplified formulas). I know there must be a file somewhere where you define these based on the width. Can someone direct me to this file or give me a hint one what I should be searching for in the help? |
Title: Re: Automatically calculating AD, AS, PD, PS, etc Post by Geoffrey_Coram on Mar 11th, 2008, 8:35am To compute the value, you need to know the diffusion dimension perpendicular to the width (note: it's not the gate length). Are you asking how to get that value? Or are you asking how you set up the Cadence CDF (component ... form) with a callback so it fills in the values automatically? (Change the width, callback changes AD and AS.) Or are you wanting to change your netlister to print out a default AD=value if there's no value specified in the form? |
Title: Re: Automatically calculating AD, AS, PD, PS, etc Post by RobG on Mar 11th, 2008, 9:15am I know the formulas and diffusion dimensions; I just need to set up the CDF that will fill the values automatically, e.g. AD=w*0.4u. Right now I'm filling out the form by hand. Your help would be enormously appreciated! |
Title: Re: Automatically calculating AD, AS, PD, PS, etc Post by Geoffrey_Coram on Mar 11th, 2008, 10:19am You'll have to search the directory tree for your PDK -- though perhaps CDS.log will give you some hints. You're looking for files ending in .cdf, they're written in skill. |
Title: Re: Automatically calculating AD, AS, PD, PS, etc Post by RobG on Mar 11th, 2008, 3:44pm Thanks for the hints - they help a lot. Another person pointed out that it can be done with iPar("w") in the CDF. This is much easier. |
