https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Help on voltage level translator https://designers-guide.org/forum/YaBB.pl?num=1206516626 Message started by nobody on Mar 26th, 2008, 12:30am |
Title: Help on voltage level translator Post by nobody on Mar 26th, 2008, 12:30am Hello, all I read an application note @ the following link. www.intersil.com/data/an/an051.pdf I found a voltage level translator can be used to turn on and off Q3 and Q4 and was wondering how to implement that translator. By the way, I also want to know exactly drains/sources of Q3 and Q4 in each phase because drains and sources are inverted in each clock and substrates need to be the most negative in every clok. Thanks. |
