https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> how to run qpss for mixer+divide by 2 https://designers-guide.org/forum/YaBB.pl?num=1206803212 Message started by silentgun on Mar 29th, 2008, 8:06am |
Title: how to run qpss for mixer+divide by 2 Post by silentgun on Mar 29th, 2008, 8:06am hi, all I recently design mixer. for accuracy I added LO circuit associated with mixer which included divide by 2 and LO buffer. when running qpss, I met problem. For LO frequency 200M, vco frequency would be 400M. but in qpss settingup form, 200M component was not available. how could I get the downconverted frequency which should equal fin-200M thanks |
Title: Re: how to run qpss for mixer+divide by 2 Post by pancho_hideboo on Mar 29th, 2008, 9:52am Set "freqdivide" parameter as two. |
Title: Re: how to run qpss for mixer+divide by 2 Post by silentgun on Mar 31st, 2008, 1:50am thank u very much problem solved :) |
