https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> IIP2 measurements https://designers-guide.org/forum/YaBB.pl?num=1207676629 Message started by vivek1214 on Apr 8th, 2008, 10:43am |
Title: IIP2 measurements Post by vivek1214 on Apr 8th, 2008, 10:43am hello, I want to measure IIP2 of my system(BT receiver).center freq 2.44GHz which tones I should take to measure IIP2? |
Title: Re: IIP2 measurements Post by Stefan on Apr 9th, 2008, 12:17am That strongly depends on the filter characteristics you chose for your system. You need to use 2 frequencies that can travel through your input filters, across your LNA/Mixer stages and so on, until they reach (downconverted) the lowpass filters and the ADC. The lowpass filters and bandwidth of your LNA/mixer combination specify the allowed distance between the two carriers, your simulation time requirements specify the minimum distance needed for effective simulation. However, when characterizing a wideband sytem, you should consider using 2.5GHz instead of 2.44GHz for easier use of fractional parameters ... |
Title: Re: IIP2 measurements Post by didac on Apr 9th, 2008, 12:35pm Hi, If you are working with a direct conversion receiver I think that you should choose two tones which their difference results directly in the IF bandwidth(DC to 3dB corner of the IF filter) since they will leak through the mixer (finite RF-LO isolation), then you can compare the resulting IIP2 with the radio spec of adjacent channel level. Hope it helps, |
Title: Re: IIP2 measurements Post by pancho_hideboo on Apr 10th, 2008, 2:34am See http://www.designers-guide.org/Forum/YaBB.pl?num=1193566207 |
