https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Current mirror OTA vs. standard diff amp https://designers-guide.org/forum/YaBB.pl?num=1208275526 Message started by jiesteve on Apr 15th, 2008, 9:05am |
Title: Current mirror OTA vs. standard diff amp Post by jiesteve on Apr 15th, 2008, 9:05am What are the advantages (or disadvantages) to using a current mirror OTA vs. a standard diffamp (with current mirror load)? Let's assume each topology is roughly single stage gain (30-40dB)... what do you get with a current mirror OTA vs. the standard diffamp? Thanks! |
