https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> Calibre PEX problem with UMC 0.13u design kit https://designers-guide.org/forum/YaBB.pl?num=1208454277 Message started by grassflying on Apr 17th, 2008, 10:44am |
Title: Calibre PEX problem with UMC 0.13u design kit Post by grassflying on Apr 17th, 2008, 10:44am I am using DRC, LVS and LPE files in Cadence (available from UMC 0.13u design kit). DRC and LVS are running but when I run Calibre-> PEX (Parasitic Extraction) the following error is generated: "Undefined layer name parameter: NSD_C" LPE file has definition rules similar to the following given below: RESISTANCE SHEET NSD_C [7.00 0] MASK RESISTANCE SHEET PSD_C [7.00 0] MASK RESISTANCE SHEET PLY_C [8.00 0] MASK Does anybody know what's the problem due to and how I can fix it? Thanks! |
Title: Re: Calibre PEX problem with UMC 0.13u design kit Post by 9patch on May 7th, 2008, 4:16pm NSD_C is missing from your LVS file. You would need a layer statement that defines the layer NSD_C, or you need to do a boolean operation to generated a derived layer called NSD_C. It would probably be best to contact UMC to get this sorted out. |
