https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Setup simulation for SCL MOS divider https://designers-guide.org/forum/YaBB.pl?num=1208873398 Message started by vkale on Apr 22nd, 2008, 6:09am |
Title: Setup simulation for SCL MOS divider Post by vkale on Apr 22nd, 2008, 6:09am Hi, I have a SCL(or CML) divider with fclk=1.5GHz and i would like to simulate in order to get the half of the clock freq. I have set the current to a value that allows to operate the transistors at the expected frequency. But I can't get the right waveform. Is there anything about Spectre(some initial condition thai I must set), or is something else? Bill |
Title: Re: Setup simulation for SCL MOS divider Post by ACWWong on Apr 22nd, 2008, 1:06pm if your SCL divide-by-2 is designed correctly and you drive the input at fclk then you should get fclk/2 at the output. There is no need for initial conditions in Spectre transient analysis to simulate this. If it doesn't work, then you have a problem with the design or setup which will not be corrected by initial conditions. More details would be needed for a better diagnosis. |
