https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Common-mode point for OPamp https://designers-guide.org/forum/YaBB.pl?num=1209668847 Message started by nxing on May 1st, 2008, 12:07pm |
Title: Common-mode point for OPamp Post by nxing on May 1st, 2008, 12:07pm Hello everyone, I have a question regarding how to setup the output common-mode voltage before connect the CMFB circuit. Should these points be close to what ever we want (for example, vdd/2) or it doesn't matter as long as the we can correct them with CMFB circuit? Thanks! Norman |
Title: Re: Common-mode point for OPamp Post by thechopper on May 1st, 2008, 2:24pm Hi Noman, The CM voltage should be selected in order to guarantee the required differential signal excursion. Then the CMFB will be the one forcing such CM level and will obviously have to be designed for working at those levels. Regards Tosei |
