https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Entry Tools >> Design Data Management https://designers-guide.org/forum/YaBB.pl?num=1210662339 Message started by achim.graupner on May 13th, 2008, 12:05am |
Title: Design Data Management Post by achim.graupner on May 13th, 2008, 12:05am Dear all, we considering using data management (DM) for DFII-data and other design data. We currently using subversion (svn) on command line but this is like hell for analog designers. At the moment we have less that a dozen designers from two sites working in a project. It is assumed that it will slightly increase in the next years (say 20 designers from two sites in a project). We do want to employ just one DM system for all data. Hence, easy command line support is required for digital design, a Windows client is appreciated as well for the spec etc. So far we had a brief look onto DesignSync/ Enovia MartixOne ICmanage SOS/ Clio VersIC/ MethodICs I like VersIC because we could stay to our svn approach. We did some evaluations with the tool. Does anyone has experiences with VersIC? I am also not sure whether the svn approach is really scalable as it creates a lot of data in the working copies. Does anyone has experience with other tools? Maybe a comparison is available somewhere? On deepchip I have not found really recent posts. Regards, Achim |
