https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> automatic table of results from corner analysis https://designers-guide.org/forum/YaBB.pl?num=1211882984 Message started by vivkr on May 27th, 2008, 3:09am |
Title: automatic table of results from corner analysis Post by vivkr on May 27th, 2008, 3:09am Hi, I am trying to figure out how I can get the Analog Design Environment from Cadence to give me a table of selected scalar results along with the corner information. Also good would be if a table of min./max. outputs and corresponding corners are included. This would be useful for documentation purposes. By default, the ADE output only gives a corner number, and min./max. values are not gleaned from the data. Any suggestions would be welcome. Regards Vivek |
