https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> sigma delta fractional-N pll https://designers-guide.org/forum/YaBB.pl?num=1212271838 Message started by chenyan on May 31st, 2008, 3:10pm |
Title: sigma delta fractional-N pll Post by chenyan on May 31st, 2008, 3:10pm In a sigma delta fractional N pll, the fractional spurs are shaped by the SD modulator which controls the multi-modulus divider. In the literatures I found, the first order approximation of quantization noise always neglect the effect of the number of bits of MMD and assume the quantization noise white. My questions are: (1) How does the bit-number of MMD effect the quantization noise and/or frational spur? (2) How can the fractional spurs be treated as noise or even white noise as in numerous literatures? (3) When the PLL has a fixed fractional division factor N+x, the quantization error should be x and 1-x with different probability density. How can this be treated same as SD ADC and get a rms value of 1/12? Thanks in advance. chenyan |
