https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> headroom simulation https://designers-guide.org/forum/YaBB.pl?num=1212744456 Message started by skas20 on Jun 6th, 2008, 2:27am |
Title: headroom simulation Post by skas20 on Jun 6th, 2008, 2:27am Can somebody please explain me fundamentally what is headroom simulation in analog circuits? - I can understand its a simulations to make sure that all transistors are having enough vds to remain in sat.region even with a slight supply voltage changes.. - what I want to know is what are the methods to understand whether a transistor has enough headroom? - do we have to run the simulation in all the corners etc... Thanks. |
Title: Re: headroom simulation Post by jiesteve on Jun 10th, 2008, 12:10am You want to check to see that your Vds > Vdsat (for short channel transistors you want to look at the Vdsat given by SPICE, it's not equal to Vgs-Vt). The worst case corner for headroom is low VDD slow corner (slow corner => transistors weaker => higher Vdsat req'd to keep in saturation) highest temperature (high temp => lower mobility => higher Vdsat req'd) and w/ transistors operating at their highest current levels (higher current => more Vdsat). |
Title: Re: headroom simulation Post by weber8722 on Mar 17th, 2009, 7:25am AnalogDE wrote on Jun 10th, 2008, 12:10am:
Let me add: Slow corner for transistors!! But fast corner for resistors!! Wether high or low temperature corner is worst-case depends on current densitity. For low current usually the lowT corner is much more critical. Bye Stephan |
