https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> balanced front-end https://designers-guide.org/forum/YaBB.pl?num=1213607077 Message started by aaron_do on Jun 16th, 2008, 2:04am |
Title: balanced front-end Post by aaron_do on Jun 16th, 2008, 2:04am Hi all, just wondering, how necessary is it to have a fully differential front-end? I'm designing for the 802.15.4 standard where interference requirements are pretty relaxed. I'm not using direct-conversion either, so DC-offset is not a major concern. I was thinking i could save a lot of power by have a single-balanced front-end (up to the output of the mixer). Any thoughts? What parameter should I look at? IIP2? thanks, Aaron |
Title: Re: balanced front-end Post by Stefan on Jun 16th, 2008, 3:08am Yes, IIP2 will be a major concern. You should also check for any self-mixing issues like LO feedthrough (LO Port to RF Port) or isolation requirements from the duplexer (I don't have the standard at hand...). If you're using a low IF or heterodyn structure those might only be critical if you're also closefisted with your filters ... |
Title: Re: balanced front-end Post by aaron_do on Jun 16th, 2008, 6:35am I was thinking that a single-balanced mixer would be able to attenuate LO feedthrough just as well as a double balanced. i.e. balance the LO but not the RF. Also by balancing the LO i can get my IF+ and IF-... cheers, Aaron |
