https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> Cadence Modelwriter, creating new template https://designers-guide.org/forum/YaBB.pl?num=1213664211 Message started by srikanthpam on Jun 16th, 2008, 5:56pm |
Title: Cadence Modelwriter, creating new template Post by srikanthpam on Jun 16th, 2008, 5:56pm Hi all, Is it possible to ceate new model templates for use with the cadence modelwriter GUI. If so, how to do that ? Any references on the format will be greatly helpful. Modelwriter is a decent UI for creating verilog-a/ams models, but if we cannot add new model templates its use is severly restricted. Thanks a lot Srikanth |
Title: Re: Cadence Modelwriter, creating new template Post by srikanthpam on Jun 19th, 2008, 4:01pm Seems its not possible to create new templates :( |
Title: Re: Cadence Modelwriter, creating new template Post by Stefan on Jun 20th, 2008, 12:24am We did some work related to the modelwriter some years ago as far as I do remember. However, in my oppinion, it's use is very limited, although it's possible to create new templates. You should check with your local sales representative or via sourcelink. Regards, Stefan |
Title: Re: Cadence Modelwriter, creating new template Post by srikanthpam on Jun 20th, 2008, 5:48pm Thanks Stefan. Looks like its only internal to cadence. Any way will try to findout, how we can get information or access. |
Title: Re: Cadence Modelwriter, creating new template Post by jbdavid on Aug 6th, 2008, 9:39am I don't know the status of the tool today.. but 4 years ago there was documentation on where to put the templates you wrote youre self and what env var to set so it knows were to find them.. Actually maybe it was longer ago than that.. As that was a project I was working on back in 2001-2002.. I think modelwriter was not a bad idea.. but perl is a more useful language for model template processing.. at least that has been my experience. jbd |
