https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> VCO phase noise https://designers-guide.org/forum/YaBB.pl?num=1213798862 Message started by Faisal on Jun 18th, 2008, 7:21am |
Title: VCO phase noise Post by Faisal on Jun 18th, 2008, 7:21am Hi, I have a question related to phase noise simulation of a "free running VCO" in SpectreRF. Using pnoise analsyis, I am able to see a phase noise value of about -55 dbC at 1 KHz. However at lower offset frequencies such as 1, 10 and 100 Hz.. I see a ridiculously high values such as 30 dbC (i.e. even higher than the carrier). I know that this is not possible in reality, but there must be some explanation to this weird result (Most probably the pnoise settings) Any ideas, here? |
Title: Re: VCO phase noise Post by Hyvonen on Jun 18th, 2008, 7:56am What's the amplitude at the fundamental oscillation frequency? At very low frequency offsets flicker noise dominates the phase noise, (usually) with a ramp of 30dB/dec. I've never simulated all the way down to 1Hz, but overall I think it makes sense that the simulation result for low-offset phase noise would be higher than the carrier power (although this is not physical). |
Title: Re: VCO phase noise Post by Frank Wiedmann on Jun 18th, 2008, 8:28am See http://www.designers-guide.com/Forum/?board=rfsim;action=display;num=1050465395;start=1#1. |
