https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> a question about rail-to-rail opamp https://designers-guide.org/forum/YaBB.pl?num=1214752977 Message started by icguy on Jun 29th, 2008, 8:22am |
Title: a question about rail-to-rail opamp Post by icguy on Jun 29th, 2008, 8:22am is there certain ciucuit that can sense the output common mode signal for the cmfb? As most of the components can't sense the rail-to-rail output signal thank you :)! |
Title: Re: a question about rail-to-rail opamp Post by vivkr on Jun 30th, 2008, 12:28am try a resistive divider, or a switched-capacitor common mode sense circuit. Regards Vivek |
