https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Syntax Error when using spectre to simulation verilog-A file. https://designers-guide.org/forum/YaBB.pl?num=1216548956 Message started by Julian18 on Jul 20th, 2008, 3:15am |
Title: Syntax Error when using spectre to simulation verilog-A file. Post by Julian18 on Jul 20th, 2008, 3:15am Hi, there I am very new to verilog-A field, so bear this simple question. I am runing Ken's sample and hold example and got the error like below: Quote:
I am just using the spectre from command line(instead of simulating in ADE) and the command is Quote: I wonder if I have to add some options in order for spectre to realize that the file contains verilog-A statements. TIA. |
Title: Re: Syntax Error when using spectre to simulation verilog-A file. Post by Geoffrey_Coram on Jul 21st, 2008, 8:57am Did you ahdl_include "sh.va" in your .scs file? (Or were you using a regular include like for model files?) |
