Simulators >> Circuit Simulators >> question about .meas in hspice
https://designers-guide.org/forum/YaBB.pl?num=1216866172
Message started by daisy on Jul 23rd, 2008, 6:22pm
Title: question about .meas in hspice
Post by daisy on Jul 23rd, 2008, 6:22pm
Hi!
I'm simulating a low pass filter and I want to see the frequency point when the output value decreases 3dB.I wrote the statement like this:
.meas ac gainmax max vdb(vout)
.meas ac band find f when vdb(vout)='gainmax-3'
however,there is a warning in the .lis file,saying that the band is not defined.So how should I describe the statement?
Thanks a lot!
daisy
Title: Re: question about .meas in hspice
Post by ywguo on Jul 24th, 2008, 12:07am
Hi Daisy,
It seems that the simulator does not identify what f is. When I try your .measure card. It report the following warning message in the listing file.
**warning** could not identify variable type f
I simulate successfully with the following cards.
Code:
.meas ac f3db when vdb(vout)='gainmax-3'
Please note that time or frequency are independent variables in a HSPICE simulator. However, we have never quote a variable like frequency or time in SPICE.
The .measure syntax is
.measure <DC|TRAN|AC> result when out_var=val
where result is time for TRAN and frequency for AC. They are independent variables.
Best regards,
Yawei
Post by daisy on Jul 24th, 2008, 2:11am
Hi! I have simulated successfully with your cards.
Thank you for your help!
daisy
ywguo wrote on Jul 24th, 2008, 12:07am:
Hi Daisy,
Code:
Best regards,
Yawei
