https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> spectre error in transient sim. https://designers-guide.org/forum/YaBB.pl?num=1218127282 Message started by lrc on Aug 7th, 2008, 8:41am |
Title: spectre error in transient sim. Post by lrc on Aug 7th, 2008, 8:41am Hi, I am running a transient simulation using spectreVerilog, the simulation always stopped by the error below. �Can anyone please tell me what might be the cause and how to avoid it? Thanks very much. Zhenning Error found by spectre at time = 61.9654 us during transient analysis `tran'. � �ERROR: Error in transient analysis IPC. � �ERROR (SPECTRE-16328): Error in transient simulation for mixed-mode. Analysis `tran' was terminated prematurely due to an error. finalTimeOP: writing operating point information to rawfile. Error found by spectre during DC analysis, during info `finalTimeOP'. � �ERROR: Error in cleaning up IPC code in an attempt to quit. � �ERROR (SPECTRE-16329): Error in DC simulation for mixed-mode. Analysis `finalTimeOP' was terminated prematurely due to an error. ****************** DC Analysis `dcOp' ****************** Error found by spectre during DC analysis `dcOp'. � �ERROR (SPECTRE-16041): Analysis was skipped due to inability to compute operating point. Analysis `dcOp' was terminated prematurely due to an error. dcOpInfo: writing operating point information to rawfile. Error found by spectre during DC analysis, during info `dcOpInfo'. � �ERROR (SPECTRE-16041): Analysis was skipped due to inability to compute operating point. |
Title: Re: spectre error in transient sim. Post by bharat on Jan 25th, 2009, 8:20am Did you get the answer to that? |
Title: Re: spectre error in transient sim. Post by Geoffrey_Coram on Jan 27th, 2009, 11:18am ERROR: Error in cleaning up IPC code in an attempt to quit. sounds like something you should report to Cadence R&D. |
Title: Re: spectre error in transient sim. Post by Andrew Beckett on Jan 27th, 2009, 12:53pm This can happen (from a little research I did) when the verilog executable dies during the mixed-signal simulation. Spectre then reports it as seen above, because it can no longer talk to it. I've found a few cases:
There seemed to be lots of possible reasons - this was just a sample. I'd look in the verilog log file and see if that gives any clues... |
