https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> flicker noise model in tsmc0.35 seems too high!! https://designers-guide.org/forum/YaBB.pl?num=1218637390 Message started by nus_lin on Aug 13th, 2008, 7:23am |
Title: flicker noise model in tsmc0.35 seems too high!! Post by nus_lin on Aug 13th, 2008, 7:23am I am so surprised to find out that the flicker noise in tsmc model are so high, which is almost 500times higher than AMS process. Although from my experience that the measured flicker noise in AMS is 5~8time higher than model, I still have to say, the flicker noise in tsmc model are too high! for AMS process, the flicker noise can be modeled as 4.4uV/(W*L)^0.5/f^0.5/(Hz)^0.5 For TSMC process, the flicker noise can be modeled as 2400uV/(W*L)^0.5/f^0.5/(Hz)^0.5 can anyone of you double check your process, and confirm with me which one is more reliable? |
Title: Re: flicker noise model in tsmc0.35 seems too high!! Post by nus_lin on Aug 14th, 2008, 12:59am design kit bug. |
