https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> ADS simulator error https://designers-guide.org/forum/YaBB.pl?num=1218806577 Message started by Turin on Aug 15th, 2008, 6:22am |
Title: ADS simulator error Post by Turin on Aug 15th, 2008, 6:22am I have an error in the simulation in ads 2004 and i wonder if anyone know how the correct it.The simulator can't start because it can't identify a the desing kit 's components. The exact ,message is Error detected by HPEESOFSIM during netlist parsing. `MP1' is an instance of an undefined model `pmos'. Status / Summary HPEESOFSIM (*) 2004A.501 Oct 12 2004 (built: 10/12/04 22:26:01) Copyright Agilent Technologies, 1989-2004. -------------------- Simulation terminated due to error. -------------------- I'm quite sure the desing kit is installed correctly..Any suggestions.....? |
Title: Re: ADS simulator error Post by pancho_hideboo on Aug 15th, 2008, 10:06pm Turin wrote on Aug 15th, 2008, 6:22am:
Show me a status report of installed design kit. Even if you can see components in pallete and place them in schematic, it is very possible that design kit is not installed correctly. Possibilties are: (1) Design Kit is not installed correctly. Site Level or User Level ? (2) Installed Design Kit is not valid for ADS2004A(this is faily old). (3) Content of Design Kit is broken or incomplete due to some reason. |
Title: Re: ADS simulator error Post by Turin on Aug 16th, 2008, 3:31am User level....The kit is specified in the documentation as ads 2004 or higher so it should be ok.... ![]() |
Title: Re: ADS simulator error Post by nanion on Aug 20th, 2008, 8:29am I think you might not have placed the process model information block in your test bench. From the component scroll down button, select your process kit and there should be a process info block. Place it on to your test bench. |
