Simulators >> Circuit Simulators >> Error using cross function of Wavescan
https://designers-guide.org/forum/YaBB.pl?num=1219225592
Message started by Pavel on Aug 20th, 2008, 1:46am
Title: Error using cross function of Wavescan
Post by Pavel on Aug 20th, 2008, 1:46am
Hello,
I try to use cross function (calculator of Wavescan) when doing temperature sweep.
Doesn't work.
The error message appears in log window.
Code:
*Error* crossMethod: can't handle crossMethod(nil 2.5 1 "rising" nil nil)
Error message reports that cross function cannot recognize voltage that I specified as 1st argument (as we can see in error message, 1st parameter is nil). Does it mean that this function works only for "true" DC sweeps, but not for temperature?
The syntax of cross function call, generated by calculator, is as follows
Code:
cross(VDC("/out") 2.5 1 "rising" nil nil)
Thanks.
Regards.
Pavel.
Title: Re: Error using cross function of Wavescan
Post by Pavel on Aug 20th, 2008, 2:08am
Resolved.
Right syntax is
Code:
cross(VS("/out") 2.5 1 "rising" nil nil)
Regards.
Pavel.
