https://designers-guide.org/forum/YaBB.pl Measurements >> Phase Noise and Jitter Measurements >> why the phase noise of ring osc is generally much bigger than driven circuit? https://designers-guide.org/forum/YaBB.pl?num=1219245601 Message started by luantan on Aug 20th, 2008, 8:20am |
Title: why the phase noise of ring osc is generally much bigger than driven circuit? Post by luantan on Aug 20th, 2008, 8:20am Dear All: In the phase noise simulatin, I find that the phase noise of ring oscillator is generally much bigger than driven circuits (for example: cml clock buffer). Why? The only difference I can think is that osc will "integrate the phase", so the phase noise of osc will have 1/f^3 and 1/f^2 region. The driven circuit does not "integrate the phase, so the phase noise only have 1/f and a noise floor. But this can not explain that osclillator's phase noise will be much bigger than driven circuit, I think. The "integration property" will only make phase noise decrease more quickly at higher frequency. So, what is the real reason behind this phenomenon? Any reply is highly appreciated. :) ---johnson |
Title: Re: why the phase noise of ring osc is generally much bigger than driven circuit? Post by Ken Kundert on Aug 20th, 2008, 9:29am Integrators have infinite gain at DC, and very high gain at low frequencies, so the integration can and does amplify noise at low frequencies. Another way of thinking of this is in terms of phase drift. In oscillators the phase can drift without bound. This is a manifestation of low frequency phase noise. -Ken |
Title: Re: why the phase noise of ring osc is generally much bigger than driven circuit? Post by luantan on Aug 21st, 2008, 7:28am Dear Ken: Yes, the noise is integrated in ring osc. This means that for frequecny < 1Hz, the noise is amplified, for frequency > 1Hz, the noise is decreased. However I see that ring osc's phase noise is much bigger than driven circuit even when frequecny >> 1 Hz. ---johnson :) |
Title: Re: why the phase noise of ring osc is generally much bigger than driven circuit? Post by Ken Kundert on Aug 21st, 2008, 10:17am There is nothing special about 1Hz. You are assuming a gain factor of one, but there is no reason to believe the gain factor on the integrator is unity. In fact, for a ring oscillator, I would expect the unity gain frequency on the integrator to be near the oscillation frequency. -Ken |
Title: Re: why the phase noise of ring osc is generally much bigger than driven circuit? Post by luantan on Aug 24th, 2008, 7:36am Dear Ken: Thanks for your immediate response, and that's was indeed helpful for me. So, the real reason is that ring osc not only "integrates noise, but also amplifies it. However as far as Hajimiri's theory is concerned, I still have one question. This well-known figure is quoted from his paper In this figure, I can see integration, I can see periodical modulation. But I can not see "amplification". May be 1/qmax is the "amplification" factor. If it is, what about driven circuit? I think that driven circuit also have this 1/qmax. So, this confuses me. (By the way, here qmax is the maximum charge displacement across the capacitor on osc's node. Hajimiri thinks that if deltaQ is injected into the node capacitor The instantaneous voltage change deltaV will be deltaV=deltaQ/C So, hajimiri uses qmax to normalize his equations.) |
