https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> MOS regime/mode verification https://designers-guide.org/forum/YaBB.pl?num=1219309244 Message started by Pavel on Aug 21st, 2008, 2:00am |
Title: MOS regime/mode verification Post by Pavel on Aug 21st, 2008, 2:00am Hello Is there a sample means to determine functional mode (saturation, conduction) and inversion level (strong/moderate/weak) in spectre/bsim3v3. Under simple means I mean some parameter that could be output rateher in textfile, rather in plot. Thanks. Regards. Pavel. |
Title: Re: MOS regime/mode verification Post by Istros on Oct 30th, 2008, 3:56am Hello Pavel, The parameter "region" gives an estimation on the operating region of a mosfet. If "region" is equal to: 0 -> transitor is off 1-> transistor is in triode (conduction) 2 -> saturation (in strong inversion) 3 -> subthreshold 4 -> breakdown Anyway it is quiete easy to determine if a current is in WI, MI or SI. You can use the inversion coefficient, (see Micropower techniques, Vittoz). Best regards, Marc |
Title: Re: MOS regime/mode verification Post by Pavel on Oct 30th, 2008, 7:58am Hello Marc Thanks for response. For "region" Ok. Concerning inversion level, it requires knowledge of specific current, otherwise calculation. When one has dozens of transistors and wants quickly estimate their inversion level, some "inversion level" parameter would be useful. Best Regards. Pavel. |
