https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Error in iPar in Spectre https://designers-guide.org/forum/YaBB.pl?num=1219863710 Message started by SiValley_designer on Aug 27th, 2008, 12:01pm |
Title: Error in iPar in Spectre Post by SiValley_designer on Aug 27th, 2008, 12:01pm I "randomly" get the following message in Spectre: "Function 'iPar' is undefined or is used recursively" My simulations run properly most of the times but sometimes all of a sudden this message shows up and interrupts my simulations. I think it has to do with the way spectre compiles the netlist. When it gives the error it does not replace the iPar() with its corresponding values. Does anyone have any experience with this? Thanks, |
Title: Re: Error in iPar in Spectre Post by als on Sep 1st, 2008, 7:20am SiV_D, iPar is used in the Analog Design Environment to allow one device parameters to be used in the definition of another device parameter. If iPar is being passed to Spectre, then there is an issue in the parameter CDF. Unlike a design variable the iPar value should be resolved before it is passed to Spectre. Best Regards, Sheldon |
