https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> verilog-A model for counter https://designers-guide.org/forum/YaBB.pl?num=1219934219 Message started by smarty on Aug 28th, 2008, 7:36am |
Title: verilog-A model for counter Post by smarty on Aug 28th, 2008, 7:36am Hi all, I am designing a temperature sensor and I would need to design a counter. But I wanted to test my design using behavioral model (verilog-A) model of counter. I am not an expert in modelling. Can anybody help me out on this. I need a counter which takes in serial input and converts it into a 8-bit parallel data. Thanks and Regards, SBR |
Title: Re: verilog-A model for counter Post by jbdavid on Aug 28th, 2008, 11:36am if you are using Cadence tools there are two libraries of interest shipped with the tools, ahdlLib, and bmslib.. there are examples of what you are looking for in there. Also there are examples here on this site that may help you out. jbd |
Title: Re: verilog-A model for counter Post by smarty on Aug 28th, 2008, 8:19pm Hi jbd, Thanks.. I am working with cadence. i will look for the two libraries u mentioned and also search this site, if I get a little bit more info. Best Regards, SBR |
