https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Receiver sensitivity https://designers-guide.org/forum/YaBB.pl?num=1220252206 Message started by Berti on Aug 31st, 2008, 11:56pm |
Title: Receiver sensitivity Post by Berti on Aug 31st, 2008, 11:56pm Hi, Is the minimum receiver sensitivity and the blocker-mask the same for GSM and EDGE, or UMTS and HSDPA, respectively? Thanks, regards. |
Title: Re: Receiver sensitivity Post by ywguo on Sep 1st, 2008, 7:43pm Berti, Why don't you refer to all the specs for those standards? Yawei |
Title: Re: Receiver sensitivity Post by ACWWong on Sep 2nd, 2008, 12:27am i seem to recall that GSM and EDGE have subtly different blocker masks and sensitivity levels on the handset side. Further differences on the basestation side exist. not sure about umts and hsdpa but i suspect they'll be subtly different too. As yawei mentioned, checkout the 3GPP standards |
