https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> use of small signal resources is not supported? https://designers-guide.org/forum/YaBB.pl?num=1220962591 Message started by nus_lin on Sep 9th, 2008, 5:16am |
Title: use of small signal resources is not supported? Post by nus_lin on Sep 9th, 2008, 5:16am hi, guys. i copied almost the same code from "the designer's guide to verilog-ams", by Ken. Kundert, our "god father". but unfortunately i got this error message: "use of small signal resources is not supported?" the code is given below: `include "constants.vams" `include "disciplines.vams" module resport(p,n); parameter real r=1 from (0:inf); parameter real dc=0; parameter real mag=1; inout p,n; electrical p,n; analog begin V(p,n)<+r*I(p,n)+2*dc; V(p,n)<+2*ac_stim("ac",mag,0); V(p,n)<+white_noise(4*`P_K*$temperature,"thermal"); end endmodule |
Title: Re: use of small signal resources is not supported? Post by Geoffrey_Coram on Sep 9th, 2008, 5:32am What simulator is that? small-signal sources (ac_stim, white_noise) are pretty basic to any Spice-like simulator, so I'm surprised there's one that supports Verilog-A but not these. Of course, if you're using a timing (aka fast-spice) simulator, it probably only supports transient analysis, no small-signal. |
Title: Re: use of small signal resources is not supported? Post by nus_lin on Sep 9th, 2008, 5:59am thank you for the reply. i used the cadence design kits for AMS0.35. |
Title: Re: use of small signal resources is not supported? Post by nus_lin on Sep 9th, 2008, 6:02am Error found by spectre during SpectreHDL compile. file: *********** nonrecoverable error: use of small signal resources is not supported Exiting AHDL compilation. |
Title: Re: use of small signal resources is not supported? Post by Ken Kundert on Sep 9th, 2008, 10:28am It's odd that the error message says "SpectreHDL". Are you sure you are including it as a verilog-A file? -Ken |
Title: Re: use of small signal resources is not supported? Post by nus_lin on Sep 10th, 2008, 12:19am hi, god father, i have no idea about spectraHDL, but i found a way to solve the "small signal resources" problem. by changing V(p,n)<+2*ac_stim("ac",mag,0); to V(p,n)<+ac_stim("ac",2*mag,0); |
