https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> how to avoid extracting RFMOS in Calibre PEX? https://designers-guide.org/forum/YaBB.pl?num=1221038883 Message started by jlee on Sep 10th, 2008, 2:28am |
Title: how to avoid extracting RFMOS in Calibre PEX? Post by jlee on Sep 10th, 2008, 2:28am To avoid extracting RFMOS parasitics in Calibre PEX, I used hcell file and gate level extraction type. Here is my hcell file: rfnmos1v nmosrf After extraction, I found following warnings. 1) Warning: Hcell rfnmos1v not located or not allowed. 2) Warning: Name "rfnmos1v" in hcell correspondence file not found in layout - ignored". In RVE, net parasitics shows that parasitics has still be extracted. I don't know how to solve this problem. Could you please give me some suggestions? Thanks in advance! Jason |
Title: Re: how to avoid extracting RFMOS in Calibre PEX? Post by ywguo on Sep 11th, 2008, 3:03am Hi Jason, It seems that the Calibre xRC had not find the cell named rfnmos1v. Yawei |
Title: Re: how to avoid extracting RFMOS in Calibre PEX? Post by jlee on Sep 13th, 2008, 12:13am Thanks for your input. What ahout my hcell file? Is it right? Which one should follow the name in layout, the former or the latter? |
Title: Re: how to avoid extracting RFMOS in Calibre PEX? Post by ywguo on Sep 23rd, 2008, 1:18am I think the former should follow the layout view name, and the latter for schematic view. -- Yawei |
Title: Re: how to avoid extracting RFMOS in Calibre PEX? Post by ywguo on Oct 30th, 2008, 2:28am Hi Jason, In the hcell file from a Big foundry, the first column contains the sub-circuit name for the RF devices; the second column contains the LVS model name defined in the LVS command file. I extracted a small layout with this file successfully. I looked at the Calibre manual for 2004 and 2007. It states that the first column is layout name and the second column is source name. I don't know which one is correct now. Maybe both are correct. Yawei |
