https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> How to introduce delay within conditional statement? https://designers-guide.org/forum/YaBB.pl?num=1222438226 Message started by vpen on Sep 26th, 2008, 6:10am |
Title: How to introduce delay within conditional statement? Post by vpen on Sep 26th, 2008, 6:10am Hi everyone! please help. :'(... I want to introduce a delay within a conditonal if statement using Verilog-A. My target code should function something like this: if ( comp_flag == 1 ) � � � � � I( VOUT, GND ) <+ transition( 0.0, rdelay); else � � � � � V( VOUT, GND ) <+ �transition( 0.0, fdelay); but since its illegal to put transition() inside if conditons i modified my code like below � �I(iout) <+ transition( 0.0, rdelay); � �V(vout) <+ transition( 0.0, fdelay); if ( comp_flag == 1 ) � � � � � I( VOUT, GND ) <+ �I(iout) ); else � � � � � V( VOUT, GND ) <+ �V(vout) ); The code has no error at compilation but the delay was not accounted in the simulation? What could be wrong with the code? or what alternative should i use? :'( :'( :'( |
Title: Re: How to introduce delay within conditional statement? Post by Geoffrey_Coram on Sep 26th, 2008, 9:45am In your modified version, are "vout" and "VOUT" distinct? Verilog-A is case-sensitive, but I'm not sure whether you were careful when excerpting your model. I'd add two new nodes: electrical int_iout, int_vout; and contribute both like this: I(int_iout) <+ V(int_iout) + transition( 0.0, rdelay); I(int_vout) <+ V(int_vout) + transition( 0.0, fdelay); then if (comp_flag == 1) I(VOUT, GND) <+ V(int_iout); else V(VOUT, GND) <+ V(int_vout); The internal nodes have 1-Ohm resistors on them that convert the current into a voltage; there are funny tricks when you both contribute and probe I(iout) as in your code. In mine, the probe is always V(x). Oh, and I assume the "0.0" first arg of transition() is just a dummy, you actually have something that changes there. |
