https://designers-guide.org/forum/YaBB.pl Modeling >> Transmission Lines and Other Distributed Devices >> PSS Simulation of mtline https://designers-guide.org/forum/YaBB.pl?num=1222470011 Message started by Maryam on Sep 26th, 2008, 4:00pm |
Title: PSS Simulation of mtline Post by Maryam on Sep 26th, 2008, 4:00pm Hi, I am using mtline to model transmission lines. I have provided data file for RLCG from 0-20GHz. I excite the circuit with a 3GHz sinusoid. The transient analysis runs fine, but the pss analysis terminates with an internal error: "Internal error found in spectre during periodic steady state analysis `pss'. " " Segmentation fault." Does anybody know what the reason of this error or the solution is. Thank you very much. |
Title: Re: PSS Simulation of mtline Post by Andrew Beckett on Jan 2nd, 2009, 4:09pm Assuming you're using a recent build of spectre, you should report this to Cadence Customer Support. Otherwise try a newer spectre version first... Regards, Andrew. |
