https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> dynamic range of sigma delta adc design https://designers-guide.org/forum/YaBB.pl?num=1222487300 Message started by min on Sep 26th, 2008, 8:48pm |
Title: dynamic range of sigma delta adc design Post by min on Sep 26th, 2008, 8:48pm I can't understand the dynamic range of sigma delta 1. Does the dynamic range correlate with reference voltage? 2. what is the definition of full scale? 3. when first start design the sd adc how can I decide the full-scale |
Title: Re: dynamic range of sigma delta adc design Post by Berti on Sep 28th, 2008, 11:53pm Hi, For your general understanding: A delta-sigma modulator is a feed-back system. For input signal larger than the max. feedback (reference voltage), the modulator can't be stable. This is your full-scale input, which depends directly on the reference voltage. Depending on the loop filter, the modulator turn instable already for smaller input signals (e.g. 0.5*vref). The dynamic range is therefore given by a lower value (SNR=0dB) and full-scale (or where SNR becomes 0dB again due to instability). Hope this helps! |
