https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Noise simulation in Cadence https://designers-guide.org/forum/YaBB.pl?num=1222852620 Message started by manodipan on Oct 1st, 2008, 2:16am |
Title: Noise simulation in Cadence Post by manodipan on Oct 1st, 2008, 2:16am Hi all, I am trying to do some noise simulation in Cadence.In that i put an input port,and select the output for noise .The simulator gives output referred noise but not input referred noise.How to get the input referred noise????? By the awy i have heard some term like transient noise simulation,what is that?? |
Title: Re: Noise simulation in Cadence Post by ywguo on Oct 10th, 2008, 10:50pm Hi manodipan, Please set the input source as a voltage source in order to observe the input referred noise. Yawei |
Title: Re: Noise simulation in Cadence Post by Geoffrey_Coram on Oct 14th, 2008, 6:21am manodipan wrote on Oct 1st, 2008, 2:16am:
Spice's "noise" is a small-signal analysis, like ac: the circuit is linearized about an operating point to compute the transfer function from the noise generators to the output. PNoise goes a step further and computes a "time-varying operating point" but again linearizes the circuit. Similar for HBnoise. Transient noise does a regular transient analysis, but then uses the noise equations to inject random amounts of charge (or voltage) and attempts to compute the full nonlinear response in the presence of noise. I think there's a whitepaper on SourceLink. It's really the only way to get the noise performance of sigma-delta converters (and other circuits that aren't periodic nor linear). But it's tricky to not lose the noise in the numerical roundoff of finite-precision computer arithmetic, and to have good convergence in the presence of the random noise. |
Title: Re: Noise simulation in Cadence Post by manodipan on Nov 17th, 2008, 1:03am Hi Geoffrey, So what is the procedure to do some transient noise simulation...Is it like first transient and then noise simulation....or do noise analysis with type time domain...what is the significance of that analysis?? |
Title: Re: Noise simulation in Cadence Post by Geoffrey_Coram on Nov 17th, 2008, 4:37am Cadence has a whitepaper on transient noise available on SourceLink; you should read it to understand the assumptions and limitations. It's a transient analysis, as I said before; the noise is injected at each timepoint during the analysis. |
Title: Re: Noise simulation in Cadence Post by Frank Wiedmann on Nov 17th, 2008, 5:55am The whitepaper can be found at http://sourcelink.cadence.com/docs/files/Application_Notes/2006/TrnoiseAN.pdf. |
Title: Re: Noise simulation in Cadence Post by manodipan on Nov 21st, 2008, 3:12am Hi Frank, can you attach the pdf,because i have to register to source link and i dont know the hostid of our license server..thanks a lot.. |
Title: Re: Noise simulation in Cadence Post by Frank Wiedmann on Nov 21st, 2008, 6:11am I'm afraid I can't because the whitepaper is proprietary to Cadence and they chose not to make it available to everyone. Try to find out the hostid of your license server and register on SourceLink. |
