https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> cdb2oa - CDB to Open Access https://designers-guide.org/forum/YaBB.pl?num=1222874542 Message started by rribeiro on Oct 1st, 2008, 8:22am |
Title: cdb2oa - CDB to Open Access Post by rribeiro on Oct 1st, 2008, 8:22am Hello all, recently installed the Cadence 6.xx and I have a BIG issue. :-/ I'm trying to pass all the work that we have in Cadence5.xx to the 6.xx but it's not easy, reading the Cadence manual and trying it's not working. :'( Can anyone have a script or a step by step how to prepare a CDB database to be ready to pass to open access format? Best Regards, Ricardo |
Title: Re: cdb2oa - CDB to Open Access Post by bernd on Oct 2nd, 2008, 2:58am You are not very detailed of what is not working. You mentioned the 'cdb2oa' database library/translator in the subject of you post. Have you used it and how? What are the error messages, if there are some? Have you read 'cdb2oa -help' for the usage? * |
Title: Re: cdb2oa - CDB to Open Access Post by rribeiro on Oct 2nd, 2008, 3:32am Now after some "debugging" and "google it" I finally can run the tool to the end and "transform" the CDB database in an Open Access one. (for me the help doc it wasn't good enough, i.e. to be able to put the tool running you need to launch the cadence in other place and then "create" a cds.lib to each library that we need to translate, on the help doc we can not read this kind of information) Now the problem is, after running the translator and when I open the layout everything is in "background" layer. Yesterday I was thinking and I realised that probably the problem is that I need a strim map table. |
Title: Re: cdb2oa - CDB to Open Access Post by bernd on Oct 2nd, 2008, 6:20am Quote:
You need to attach your technology library to your design library that should be all. Command Interpreter Window (CIW) -> Tools -> Technology File Manager ... ->Attach ... In general you first translate your reference libraries (e.g. technology library) and after them your design libraries. May I ask if there is any essential reason why you have to tranlate you database? Quote:
By the way a stream in mapping table is used for reading in GDSII databases and has nothing to do with tranlating database form CDBA to OA * |
Title: Re: cdb2oa - CDB to Open Access Post by rribeiro on Oct 2nd, 2008, 6:48am Quote:
Well I downloaded the technology library, in this case TOWER, and "reference" this "new library" on my cds.lib, until here everything is ok. Quote:
The essential reason is, now I'm starting one brand new project and for this one it's not the main issue but the previous one is. I want to be able to understand this "translator" to be able to "move" the previous CDB project to this Open Access, why?!? I don't know if the designers will want to re-use some of the block's in this new one, and instead of spending time re-doing everything again I will spend some time now understanding and be able to do this translation. Quote:
Probably you are right, the thing is like I said to you I made some "google" regarding this issue and one of the bit's was related to a Strm table and I tried to use it, but like I said it's the same. Thanks for your time trying to help me "debugging" this issue. Best Regards |
Title: Re: cdb2oa - CDB to Open Access Post by rribeiro on Oct 28th, 2008, 4:30am Just to give the feedback about this issue/problem. Last week I had a person from Cadence to see the problem and to help me surround it. By steps and forgetting the "Conversion Tool Box User Guide" from Cadence help we have: 1- create a new directory 2- create a cds.lib file and DEFINE the new "pdk" (open access one) 3- run cdb2oa.csh And voila ..... you succefuly translate from cdb to oa format. Now the main problem is if the new pdk have some changes on the purpose from some layers .... in my case the technology chance from lc purpose to dg in some layers and with this the translator can not make the reference from the previous pdk (cdb pdk) to the new pdk (oa pdk) Hope this help and if you have more problem I suggest to make a request to Cadence Source link, they will be helpful. Best Regards |
Title: Re: cdb2oa - CDB to Open Access Post by lord_estacado on Jul 8th, 2009, 3:57am Hi, I'm trying to translate the cdb libraries to oa. I've followed this instructions (http://www.ece.utexas.edu/it/setting-up-the-cadence-environment/#cdb-oa-database-conversion) but I get a lot of warnings and errors: WARNING (CDBOA-406): Directory <path>/<name> is in a cellview. The directory and its contents will be copied to the destination database but will not be translated. WARNING (CDBOA-413): The OpenAccess cds.lib definition for library "name" points to CDBA data. The translator will fail if the library you are translating attempts to reference CDBA data from OpenAccess. Remove the definition from the OpenAccess cds.lib file or redefine it so that it points to OpenAccess data. WARNING (CDBOA-502): Cannot find technology information for library <path>/<name>. Translating the library without technology information. Generated once. The translator is unable to find any technology information for the library. There is no technology library attached and no valid technology file (tech.db) in the OpenAccess library directory. Fix the technology references in the CDBA version and run the translator again or attach appropriate technology information in the OpenAccess version of the library. ERROR (CDBOA-612): {Cell | View} <path>/<name> has an illegal CDBA name. Its contents will be copied to the OpenAccess version of the library but will not be translated. Generated 2 times. The translator does not convert cells or cellviews that have illegal CDBA names. The contents are copied to the OpenAccess version of the library but are not translated. This could mean that you end up with CDBA data in the OpenAccess version of your library. Check the cell or cellview in question and, if it is required, ensure that it has a legal CDBA name and then run the translator again. Can anyone help me, please? Thanks! |
