https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Jacobian error in Cadence veriloga simulation https://designers-guide.org/forum/YaBB.pl?num=1223461788 Message started by gandhi_gaurav on Oct 8th, 2008, 3:29am |
Title: Jacobian error in Cadence veriloga simulation Post by gandhi_gaurav on Oct 8th, 2008, 3:29am I am trying to run a simple simulation to calculate the amount of charge that passes through a simple device and am getting a "jacobian" error. The code that I am using is very simple as follows: `include "constants.vams" `include "disciplines.vams" module res1(out,in); inout out,in; electrical out,in; real i,charge,finalcur; analog begin i= I(out,in); charge = idt(i); finalcur = ddt(charge); end endmodule The stimulus is a simple voltage source with 1mOhm resistance connected in series to voltage source. This is then applied to the veriloga block I have designed. and the error that I am getting is zero found in diagonal of Jacobian. Any guesses what am I doing wrong ? How can I calculate the amount of charge that is passing through a device ? |
Title: Re: Jacobian error in Cadence veriloga simulation Post by Ken Kundert on Oct 9th, 2008, 3:53pm You need to specify an initial condition for the idt operator. -Ken |
Title: Re: Jacobian error in Cadence veriloga simulation Post by gandhi_gaurav on Oct 31st, 2008, 3:40am Perfect !! It works !! |
