https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> use of unix variables within verilogams https://designers-guide.org/forum/YaBB.pl?num=1223560691 Message started by idriss on Oct 9th, 2008, 6:58am |
Title: use of unix variables within verilogams Post by idriss on Oct 9th, 2008, 6:58am Hello I would like to open a file by using a unix variable in my path within a verilogams code. for example I can use this $fopen(home/project/list.in); but when I use $fopen($work/list.in); there is no error in compilation and elaboration,but the file is not open. Is anybody knows how to open file using unix variable within verilogams thakn you very much Idris |
Title: Re: use of unix variables within verilogams Post by jbdavid on Oct 9th, 2008, 6:14pm This is the way I do it.. Code:
jbd |
Title: Re: use of unix variables within verilogams Post by idriss on Oct 10th, 2008, 6:41am Hi jbd Thank you very much for the tip,it works perfectly,but the thing I didn't find any litterature about this system function $system even in the verilog manual,where can I find a complete list of systeme function of verilogams do you know that. I have an other question jbd: you see I would like to define timescale like this `timescale time_unit/time_accuracy so when i will be in a always block when I have a delay I just need to do #(delay/time_unit)..... So I can do like this `define time_accuracy 1fs `define time_unit 1fs `timescale `time_unit/`time_accuracy but the problem time_unit is in fs or delay has to be divided in f and not in fs,becasue it's a real parameter. do you have an idea how to get ride of the s in order to use with delay . Regards Idris |
Title: Re: use of unix variables within verilogams Post by jbdavid on Oct 16th, 2008, 1:58pm $system was in the original Verilog-XL product, as its documented in that manual.. but it would be clumsy to standardize it, what would work on Windows (that new OS some folks were just starting to use back then) didn't work the same way in Unix. So I guess MOST of the vendors implement this (ie cadence) but its not in the standard |
