https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> jitter simulation in hspice https://designers-guide.org/forum/YaBB.pl?num=1223820098 Message started by wwm101 on Oct 12th, 2008, 7:01am |
Title: jitter simulation in hspice Post by wwm101 on Oct 12th, 2008, 7:01am there are two problems confuse me First ,we konw we can use cosmoscope to calculate the total jitter by eye diagram through tran simulation, but the result is too big to discredit it.for example i calculate the jitter of a ideal pseudo-random numbers ,the total jitter is as high as 115ps. the netlist and calculation picture is as follow .option probe V_V2 IN 0 LFSR (-1 1 5n 0.01p 0.01p 4G 21 [21,2] rout=100) R1 IN 0 100 .tran 0.01n 100n .probe tran V(IN) .end [img][/img] how to explain this result? second ,how to calculate DJ and RJ respectively? thank you for your attention in advance! |
